It is currently Fri Jul 18, 2025 4:57 pm
PostPosted: Fri Nov 24, 2006 8:49 am
I get to go into work and check on test I'm running and then put in new bathrrom sinks
The really bad part is I have a guitar resdy for strings, well almost ready for strings. It needs the nut and saddle and such.
PostPosted: Fri Nov 24, 2006 8:51 am
That is a very productive day Todd, i wish i could have had that much free time but this evening, i'll attempt closing up the SJ box i'm workin' on!
Have a good week end Todd and everyone! Serge Poirier39045.7031365741
PostPosted: Fri Nov 24, 2006 10:40 am
Awesome - thats some great progress & good tips too - thanks!
Man you got some nice molds and sets now.
Well spent afternoon Id say.
Charliewood
PostPosted: Fri Nov 24, 2006 11:11 am
Well done Todd! Long hours, family demands and little shop time...I feel your pain    Great feeling once you get in there!!
I like your resaw set-up!
PostPosted: Fri Nov 24, 2006 1:40 pm
[QUOTE=ToddStock] [/QUOTE]
Incredible! You feed in plywood and it comes out bubinga!!! Resaw wizardry!!!
Nice, clean work, Todd. Well done!
PostPosted: Fri Nov 24, 2006 1:57 pm
First name: Jim
Last Name: Kirby
Todd - what blade are you using from Woodcraft?
I was doing the same thing today, but was having trouble getting enough tension on the blade. I think the tensioning spring may be getting weak. I had the 3/8" Timberwolf blade on, and had it cranked up past the 1/2" mark on my Delta cast iron saw. I've never had to do that before. Brand new blade, too.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Nov 24, 2006 4:10 pm
Progress on the shop - the guitar wood moved from the spare bedroom back out to the shop today. Getting closer to the 'grand reopening'
PostPosted: Sat Nov 25, 2006 12:55 am
First name: Jim
Last Name: Kirby
[QUOTE=ToddStock] Jim:
I think your instincts are right - the stock Delta spring is pretty fatigue-prone. I swap in a new Iturra (or Carter - same thing) - which is essentially a high grade valve spring - every 2-3 years. It helps.
With a sharp blade, I usually just run the tension to the 3/8" spot (between 1/4 and 1/2) and call it done unless the blade starts slapping.
Todd - Thanks for the pointers. I'm doing a big batch of Woodcraft bubinga (same as you I think?) I've never had to crank up the tension beyond the 3/8 mark before, so when the spring fails, it seems to fail fast.
Jim Kirby
kirby@udel.edu
